Skip to content
AgOpenGPS Docs
Search
Ctrl
K
Cancel
Getting started
Hardware
Software
Discourse
Telegram
YouTube
GitHub
Select theme
Dark
Light
Auto
Menu
Getting started
Hardware
Hardware quickstart guide
Boards
Boards - All-In-One
All-In-One Board guide
AIO v2.x issues and fixes
AIO v4.x issues and fixes
Assembling the board
Components you can do without
Electrical testing and validation
Reading LEDs
Other pieces to be able to assemble
Ampseal 23 pinout
Ampseal-Wiring-Harness example
Boards - Configuration
Configuring the F9P
Configuring the Teensy
Configuring your tablet
Boards - Others
Brians old board
Legacy solutions
Implement Boards
Machine Board for relay control
Machine board - full guide
Rate Controller for variable rate and section
All-In-One Version 5
Steering Options
DIY motor
Keya motor
Hydraulic valve
Danfoss valve
CANBUS
Other components
GNSS / GPS Modules
GNSS Antenna
Teensy 4.1
Inertial Measurement Unit
Wheel Angle Sensor
Windows Tablet
Cytron MD13S driver
Connectors
Cabling and Wiring
Miscellaneous hardware
Networking
3D prints and designs
Suppliers and scammers
Frequently Asked Questions
Software
What is AgOpenGPS?
Install AgOpenGPS and AgIO
AgIO Orientation
AgOpenGPS Orientation
Ethernet Setup
RTK Setup
UDP Monitor
Serial Monitor
FAQ
Safety and disclaimer
Getting started
Hardware
Software
Discourse
Telegram
YouTube
GitHub
Select theme
Dark
Light
Auto
TODO: If you’re not going CANbus, you can do without these.
