Skip to content
AIO v2.x issues and fixes
This page will aim to collect all the issues / fixes / improvements one can do having a v2.x board.
The Input diode can only handle 3A Cytron can do a lot more than the traces
Using it via 24V is okay or with relays it’s okay as well.
12V 5-6A motor however requires users to add some extra wires.
Micro: image
Standard: image
The AiO’s pressure input was meant for 20mA sensors, the above should modify it for variable voltage input
Use the correct resistors as needed. For example, 5V input, use a 1:2 ratio (eg, R1 3k, R2 6k or 5k to be safe) For 0-12V input, use a 3:1 ratio (eg, R1 6k, R2 2k)
Micro: image
Standard: image
Standard:
Micro:
The reason for swapping the 330ohm to 1kohm is because linking PWM2 Cytron to Teensy with 10ma is too much - they recommend 4ma max.
