AIO Board Pinout
So, you’ll be needing some Ampseal connectors. Please note that ground pins of 4,21,23 are common and shared, thus they can be interchanged.
ComponentPinDescription
Battery +22+12v in, use the appropriate fuse!
Battery -23 (4,21)Ground
WAS 5V15V output for Wheel Angle Sensor
WAS GND4 (21,23)Ground for WAS
WAS Low3Used for the Differential setup in AgOpenGPS
WAS High2Used for Single with GND and Differential with WAS Low
Steerswitch8Can be used with a switch or a button to have a physical button to enable / disable autosteer. Basically it allows to disable the steering. Has to be connected to ground. (4,21,23)
Workswitch9Can be used to turn sections on / off. Has to be connected to ground. (4,21,23)
Remote/Pressure10Used for pressure sensor in valves or encoder in motor. Ground: (4,21,23)
Left5Power output for motor / valves (Danfoss Signal)
Right/Lock6Power output for motor / valves (Lock was only available on AIO boards v2.5 and lower since V4 board lock is no more present)
Lock7Switched 12V output when autosteer is enabled. Can be used to activate the hydraulic valve through a relay or power Danfoss valve.
CanH116Can High for channel 1
CanL117Can Low for channel 1
Speed +14Output speed pulse +
Speed -15Output speed pulse -
A1211!Use at your own risk! Unprotected connection to Teensy pin A12
A1312!Use at your own risk! Unprotected connection to Teensy pin A13
A1413!Use at your own risk! Unprotected connection to Teensy pin A14
+12v out2012V output (use it only for limited load maximum 1A)
V2 board:
CanH218Can High for channel 2
CanL219Can Low for channel 2
V4 board:
Cytron IN18V4 board: Cytron Input (up to 10A fuse) 12/24V
NC19NC
example for motor with external freewheel mod: image
